Panko 2,480 Posted November 8, 2014 Hi guys, I want to mount 2, maybe 3 auxiliary gauges into the wagon, just to keep an eye on things. the main one i want to fit is fuel pressure (being EFi) and the other main one is volts. Yes my car is a ghia, and yes i have volts on the dash, but its only in bars, no numbers. I want something analogue that i can actually read. the third is oil pressure. so, my ideas was to mount them in the pocket in front of the manual shifter in the centre console (XF). who has mounted gauges down there before? how have you done it? please post photos to give me some ideas 1 Ecksef reacted to this Share this post Link to post Share on other sites
Ecksef 129 Posted November 8, 2014 Keen on the same idea! Share this post Link to post Share on other sites
PRO250 1,506 Posted November 8, 2014 look at sic xes one he has done itmine are in the dash on on top of the dash cant put up pictures and I give up trying to work it out 1 wagoon reacted to this Share this post Link to post Share on other sites
bigpaulo 239 Posted November 8, 2014 i pulled out the ashtray under the radio and fit a 2inch guage in there. i never mounted it properly but it fits in the cavity perfectly. You could probably make up a nice bracket/faceplate to go around them Share this post Link to post Share on other sites
adrianphu123 73 Posted November 9, 2014 took the factory console out and made my own. One thing you do have to consider mounting it there is angling the gauges up so that you can see them from your driving position. They're hard to see down there as it is, anything to make it easier. I'll try and get some photos when i have time Share this post Link to post Share on other sites
adrianphu123 73 Posted November 9, 2014 Turns out i had one already, I havent cleaned up the welds on the front side (i got impatient and just wanted to get it on) but theres water temp, oil pressure and fuel. I had to get a fuel gauge because the LPG sender wasnt compatible with the factory fuel gauge 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Panko 2,480 Posted November 9, 2014 i was looking at just mounting them in the factory pocket down there, which is angled up anyway, but they are straight towards the back of the car, rather than towards the driver, which I'm ok with. Share this post Link to post Share on other sites
Ecksef 129 Posted November 9, 2014 I've got the AU console in mine and I'd really like to get my hands on one of these custom holders, however it seems to be impossible now.. I'm actually contemplating getting some automotive styling clay and shaping it (slightly smaller than needed) then wrapping the clay in fibreglass. It'll be one hell of a job, but I'd have one killer out of the way gauge pod. Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted November 10, 2014 I did this many moons back, was an afternoons job and could have been refined a bit more but i ended up with an AU console in there aswell so it was never finished. 1 Brendon reacted to this Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted November 10, 2014 Just a simple sheet of 3mm aluminum bent to shape and fitted over the entire face plate as the hole was a lot larger than the B&M coverplate would cover. then i just gave it a brushed finish with some 20 grit paper on the belt sander and then painted it flat black and then sanded off the face with some 600 which left the paint in the grooves and polished on the ridges. Did something similar with the trip computer but out of 3mm perspex sheet 2 NZXD and PH351 reacted to this Share this post Link to post Share on other sites
Panko 2,480 Posted November 10, 2014 I really like that clint, how did you go with the pocket behind the hole? Is there enough room to put the gauges to go in without them getting cuaght up on the pocket behind? Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted November 11, 2014 Probably would be, but its easy enough to remove it anyways, just a few plastic clippy things and it falls off. its not like your going to ever use it are you LOL 1 Panko reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted November 11, 2014 Dunno about all states in Oz, but, (in SA - the Granny state) fuel pressure has to be mounted OUTSIDE the cabin. In case they leak and spray fuel all over the passenger while they're having a scoob.....Usually get mounted on the cowl in front of the driver. 2 MNTL.XD and Outback Jack reacted to this Share this post Link to post Share on other sites
Panko 2,480 Posted November 11, 2014 Probably would be, but its easy enough to remove it anyways, just a few plastic clippy things and it falls off. its not like your going to ever use it are you LOL Haha no i wont be haha. Dunno about all states in Oz, but, (in SA - the Granny state) fuel pressure has to be mounted OUTSIDE the cabin. In case they leak and spray fuel all over the passenger while they're having a scoob.....Usually get mounted on the cowl in front of the driver. Thats only for mechanical fuel pressure guages, where the gauge requires a fuel line up to the back of the gauge. We have the same rule in victoria. But the gauge i am ordering has an elctronic sender like an oil pressure gauge, so there is zero fuel inside the cabin 2 bear351c and Outback Jack reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted November 11, 2014 Cheers for that. 1 Panko reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted November 12, 2014 I've got mechanical gauges in my BnS basher. I used copper line for the oil pressure gauge instead of the nylond shit that comes with the gauge. I had a mechanical water temp gauge but it fucked up so i threw it in the bin. Heres my setup Started with 3 gauges under the dash Now back down to 2 gauges, relocated the UHF too The tacho partly covers the speedo Copper oil line FTMFW!! 1 Thom reacted to this Share this post Link to post Share on other sites
XF0747 69 Posted November 22, 2014 i wouldn't bother with a fuel pressure gauge as the factory fuel regs aren't rising rate and sit at a constant pressure (38 to 42psi, of memory), if you had and adjustable fuel reg, i'd be telling you to get one 2 Panko and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Panko 2,480 Posted December 2, 2014 yeah i agree George, but the reason i went with a fuel pressure gauge is mainly for monitoring it. i occasionally get fuel surge issues, where it would appear fuel pressure is dropping off. it could be as simple a fuel pump about to die, but at least ill be able to keep an eye on it. Share this post Link to post Share on other sites
Thom 6,650 Posted December 2, 2014 I get it all the time on hard lefts in my wagon been thinking about putting a surge tank in it for a while, it fixed the problem in my xh 2 Panko and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
broken-wheel 659 Posted May 3, 2015 I'm moving everything from he XF to the XE so i'll use Water, Oil, Fuel on the centre console speaker grill and Tach and Wide Band on the right piller The wiring will be a nightmare this time thou as I'm not sure if I want to get the ARC-8000D or the ARC-12000D on the top right corner of the windscreen and the XE wiring harness is piss weak compared to the XF, simpler yes, weaker yes Share this post Link to post Share on other sites
