Sign in to follow this
93xf
EF Crank to C4 Flexplate, which one?
Recommended Posts
Oh hang on a minute...for you can I suggest a SFI rated neutral balance (I think Thom will confirm or deny this) Windsor unit.Or Magnum do a decent replacement unit to suit,thats all I run but they are better than stock and needed.Get some ARP Toyota bolts...I'll see if I have the part number.A Windsor tension ring would be good if you can find 1 or just use good hardened washers and a careful lock tight procedure.
Share this post
Link to post
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
