93xf 2 Posted September 20, 2014 What flexplate do people use behind a crossy with an EF crank to C4? Cheers. Share this post Link to post Share on other sites
revhead 1,392 Posted September 20, 2014 should be the same from xb on as ive put xf fly wheels on e series motors and vis versa Share this post Link to post Share on other sites
Gravelrash 36 Posted September 20, 2014 uses the same flexplate as mentioned above but you may need the metric bolts from EA onwards. Share this post Link to post Share on other sites
slydog 7,873 Posted September 20, 2014 Oh hang on a minute...for you can I suggest a SFI rated neutral balance (I think Thom will confirm or deny this) Windsor unit.Or Magnum do a decent replacement unit to suit,thats all I run but they are better than stock and needed.Get some ARP Toyota bolts...I'll see if I have the part number.A Windsor tension ring would be good if you can find 1 or just use good hardened washers and a careful lock tight procedure. 1 gerg reacted to this Share this post Link to post Share on other sites
