xr6tjet 98 Posted September 10, 2014 HI guys, Trying to get the cruise control working in my 1985 XF ghia but can't seem to get it going. It doesn't engage or do anything when I hold set or the cruise button. Anybody know how to go about diagnosing them? I really want to get it fixed! Cheers, Alex. Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted September 10, 2014 Do your brake lights work? It won't work if they don't. Share this post Link to post Share on other sites
xr6tjet 98 Posted September 11, 2014 They do work however I had to remove the trip computer bulb for the warning, when I pressed the brakes the warning would light up which was annoying. I really want to get the cruise going now Share this post Link to post Share on other sites
xr6tjet 98 Posted October 1, 2014 I have done some further investigation to the cruise control issue. The later 86 cruise modulators are different from the 1985 ones. The 1985 ones have an earth wire coming directly from the vaccum case to be earthed on the body. The newer ones have the earth connection within the plug loom which plugs into the engine loom. The 1985 doesn't have the earth source in the loom hence why the later model cruise wasn't working. So what I did was grab the throttle cable from my original modulator and transferred it over to the original cruise control modulator that came with the car. Checked the brake lights and they work fine and power gets directed to the cruise ecu no problem. The modulator earth is earthing just fine to the bracket as I've tested it with a multimeter. Still nothing is happening and I have no idea what it could be. Were these vacuum modulators prone to failing? Is there any way of checking whether it works? Could it also be my actual throttle cable being too new and tight? It's a brand new one which is nice and tight in terms of pedal. Even if I press set on the cruise control not even a sign of the cruise working happens. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted October 1, 2014 Doubt it'd be due to the throttle cable, the cruise cable actuates on the throttle body so it shouldn't affect it. Cruise control pod? Computer behind dash? Share this post Link to post Share on other sites
xr6tjet 98 Posted October 1, 2014 Doubt it'd be due to the throttle cable, the cruise cable actuates on the throttle body so it shouldn't affect it. Cruise control pod? Computer behind dash? I've changed the cruise control computer (I have two) and the little red light is on when I hit the brakes and it flickers when I turn the cruise on. Starting to think its the cruise control pod. Not sure what else it could be it's just annoying! Share this post Link to post Share on other sites
bear351c 10,260 Posted January 31, 2015 Any updates?? Mine don't work either. Share this post Link to post Share on other sites
tpak addict 1,909 Posted January 31, 2015 Mines the same.... Changed the cruise control ECU and the cable thingy on the firewall... still no luck Share this post Link to post Share on other sites
xr6tjet 98 Posted February 2, 2015 Nope I couldn't get mine to work, tried a low mileage cruise unit which is in perfect condition no avail. Noticed they were different from my original one so I put the cable from the new one on my old one. Tried swapping ECU's behind the trip computer but no success. Still no idea why it won't even show me a sign of it working, literally nothing happens when I press the set button. 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,260 Posted February 2, 2015 Bummer.......same as mine. 1 tpak addict reacted to this Share this post Link to post Share on other sites
tpak addict 1,909 Posted February 2, 2015 at least I am not the only one...... Share this post Link to post Share on other sites
dex 2,065 Posted July 18, 2017 Anyone have a pic of the cruise ecu behind the trip computer ,? Share this post Link to post Share on other sites
deankxf 20,231 Posted July 18, 2017 6 minutes ago, dex said: Anyone have a pic of the cruise ecu behind the trip computer ,? pictured 2.. only one is in the car 1 dex reacted to this Share this post Link to post Share on other sites
dex 2,065 Posted July 18, 2017 Champion ,,! Big bugger ehh ,? Know what to look for now thanks dean . Ohh ehh ,, do you own a kdx 200 ? Share this post Link to post Share on other sites
dex 2,065 Posted July 18, 2017 Also ,, no difference in early to late ones as mentioned above with the wire that goes into the loom ,,,? It does not return to the computer ,,? sorry if sounds like a stupid question Share this post Link to post Share on other sites
deankxf 20,231 Posted July 18, 2017 30 minutes ago, dex said: Also ,, no difference in early to late ones as mentioned above with the wire that goes into the loom ,,,? It does not return to the computer ,,? sorry if sounds like a stupid question not sure if there are different models, i assume they are all the same.i recently sold the above pictured on ebay, and a cruise kit with a few more of those modules, were all same part number.. were probably all from ZL fairlanes though.. they all had the same plug 35 minutes ago, dex said: , do you own a kdx 200 used to.. had a 1986 one first, then a 2001 model(in 2004 for a few years) haven't ridden anything since selling it, brother took me on the back of his WR450 though, very impressive.. 1 dex reacted to this Share this post Link to post Share on other sites
dex 2,065 Posted July 18, 2017 Cheers for the info ,, invaluable . Good ol bike the original kdx . A classic . One on my radar Restod vinduro / vmx bikes are fetching beaut money these days . I dont go much on the new high rev modern 4 strokes that need more regular fettling than a 2 stroke Share this post Link to post Share on other sites
deankxf 20,231 Posted July 18, 2017 never touched the 2001 model.. well, broke the chain on first ride.. fitted an Oring one,jobs done!.. oil changes and fuel and rear tyres were the only thing it ever needed.1986 one was fun, needed the crank case split because the seals were gone and it was running on sump oil and fouling the plug.. should have spent the $400 to fix, rather than $5000 on the new one maybe ? nah, lifting the wheel in 3rd was better Share this post Link to post Share on other sites
dex 2,065 Posted July 18, 2017 was meaning the wr ,, plus im a honda bloke Share this post Link to post Share on other sites
deankxf 20,231 Posted July 18, 2017 6 minutes ago, dex said: was meaning the wr ,, plus im a honda bloke brothers first bike put me off them.. RFVC 4 valve head cracks on the 1984 XR250.. was a nice bike otherwise.. i had a KLR250 1984.. drove that into a VH commodore.. not recommended 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
dex 2,065 Posted July 19, 2017 Thats one way to try n take another commy off the road i spose ,, hahahaha Share this post Link to post Share on other sites
deankxf 20,231 Posted July 19, 2017 1 hour ago, dex said: Thats one way to try n take another commy off the road i spose ,, hahahaha $1500 damage to a $3000 car.. they fixed it.. Share this post Link to post Share on other sites
