XFute-1JZsoarer 140 Posted August 19, 2014 Can anyone confirm if it's ok to use the thinner fuel return hard line from a XF ute in a EFI setup? I know I need to use high pressure rubber lines at the ends of the hard lines, but can I keep the return line from the old mechanical fuel pump instead of replacing the entire return line from a XG/XH. Or will it be too thin for the 4L to operate properly? I'm only running a mildly worked XR6 engine... Thanks in advance. Jay. Share this post Link to post Share on other sites
Stevemack 122 Posted August 22, 2014 Hmmm, i reckon give it a try, whats it gonna do, give you higher fuel pressure? oh no! lol 1 Codeman1 reacted to this Share this post Link to post Share on other sites
xm-221 1,803 Posted August 24, 2014 I'll check my setup tomorrow for you, am pretty sure it's the standard EFI return line. 1 XFute-1JZsoarer reacted to this Share this post Link to post Share on other sites
XFute-1JZsoarer 140 Posted August 24, 2014 That would be awesome mate, I remember the lines looked the same when I stripped the XG. Pretty sure that was why I left them in it. I've still got the rubber lines that connect the tank to the hard lines put away somewhere, suppose I could just find them and see if they'll fit. Otherwise I'm considering replacing the whole lot with rubber EFI hoses. Share this post Link to post Share on other sites
xm-221 1,803 Posted August 26, 2014 Mine has 3/8th rubber hose for the feed line, standard carb feed line has been converted to the return line. Share this post Link to post Share on other sites
XFute-1JZsoarer 140 Posted August 27, 2014 Thanks mate, I might try do the same instead of using 2 rubber lines. Would have to be safer I'd reckon... Cheers. Share this post Link to post Share on other sites
