JGP 14 Posted June 3, 2014 Gents, In todays heavy melbourne rain I noticed a drop of water where the rear window demister is connected (see pic with orange circle). Does this mean the rear window seal needs replacing or something else is going on? Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted June 3, 2014 Was it just 1 drop? If so i wouldn't loose sleep. Could have been condensation build up from inside the car and there is nothing wrong with your window seal at all? Could be something more sinister and have rust under the seal and the H2o is getting in? Get a mate to jump in the back seat and you stick the water hose in that area and see if you can see whats going on. 1 Stevemack reacted to this Share this post Link to post Share on other sites
JGP 14 Posted June 3, 2014 good call mate I will get a hose onto and check it out. Share this post Link to post Share on other sites
BigCav 464 Posted June 3, 2014 another tip is to use a smoke machine inside the cabin and see if it leaks smoke outside 1 JGP reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted June 3, 2014 another tip is to use a smoke machine inside the cabin and see if it leaks smoke outside Good tip, but I think most of us are more likely to have a hose than smoke machine 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted June 3, 2014 Good tip, but I think most of us are more likely to have a hose than smoke machine Polson, your not thinking 'outside the box' 2 clevocortina and Mr Polson reacted to this Share this post Link to post Share on other sites
jamie247 542 Posted June 3, 2014 Unless your mate has some good hydro and big bertha bong Share this post Link to post Share on other sites
nickd 111 Posted June 3, 2014 Gents, In todays heavy melbourne rain I noticed a drop of water where the rear window demister is connected (see pic with orange circle). Does this mean the rear window seal needs replacing or something else is going on? I would do the smoke/water test first run your fingers across the inside of the roof lining to see if there are any damp spots. Another theory is if you have water entering the car you will find (dampness/foggy) your windows will fog up from the inside of car. If your window has been taken out in the past and hasn't been sealed properly you have water getting in I suggest you get a windscreen bloke to come out take window out clean rubber seal (you can do yourself) and re-install rear window knowing that it's been re-sealed. If you do decide to take the window out you will see where the water is getting in and if there is any surface rust you can sand and clean tidy it up. Wouldn't surprise me if its surface rust started to appear very common for these cars. Probably cost you $70-80 for windscreen guy as it will be a good investment. Hope this helps and best of luck look forward to hearing what the end result is. 1 JGP reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,864 Posted June 5, 2014 Polson, your not thinking 'outside the box' No no no....... this is how you do it - 1 XES reacted to this Share this post Link to post Share on other sites
hendrixhc 10,918 Posted June 5, 2014 Get a mate to jump in the back seat and you stick the water hose in that area and see if you can see whats going on. Just make sure you put the hose on the outside! Share this post Link to post Share on other sites
hendrixhc 10,918 Posted June 5, 2014 Jeez havent seen that movie for years. Share this post Link to post Share on other sites
nickd 111 Posted June 5, 2014 good call mate I will get a hose onto and check it out. How'd you go JGP? Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted June 6, 2014 Jeez havent seen that movie for years. Its a cult film classic isn't it Share this post Link to post Share on other sites
JGP 14 Posted June 6, 2014 How'd you go JGP? Yeah not bad. I set the hose on jet and ran it over the area, couldn't see any leakage. In saying that I reckon its still a good idea to replace the seal, at least then I can check if there is any rust forming etc.... Share this post Link to post Share on other sites
