matt_lamb_160 252 Posted May 25, 2014 Hi all, Anyone know of a compact 0.6 A/R direct bolt on compressor cover for a GT3582R other than this one: http://www.himni-racing.com/turbochargers/garrett-compressor-housings/garrett-gt3582r-turbo-compressor-housing-compact Regards, Matt Share this post Link to post Share on other sites
XPT 673 Posted May 25, 2014 The GT35R on XR6T's are 0.50AR I believe, you probably know it already but they are pretty compact and can support 400rwkw. Share this post Link to post Share on other sites
matt_lamb_160 252 Posted May 25, 2014 They have a different comp wheel don't they? If not that would be great. Will give me a lot more room and get further away from surge (not that it is a problem) My turbo is a 0.7 A/R Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted May 25, 2014 not sure about the comp cover but they definitely are 0.5 A/R go on garrets website and you can't find them with anything but 0.7 though... go figure. Share this post Link to post Share on other sites
XPT 673 Posted May 25, 2014 The BA-BF2 run the GT3582r(3540r) comp wheel: inducer 61.4mm, exducer 82mm (hence the 82 in 3582r) The FG runs the GT3576R which has a slightly smaller comp wheel. I'm sure a turbo repair mob would probably have one laying around. People do get comp covers and or wheels upgraded Share this post Link to post Share on other sites
matt_lamb_160 252 Posted May 25, 2014 I recon you're right. I want to 'down grade' to FG specs effectively. Share this post Link to post Share on other sites
XPT 673 Posted May 25, 2014 Both the BA/F and FG run the 0.50AR comp cover it's just the FG would be machined for the smaller (58mm ind, 76mm ex)comp wheel, if you already have the 3582 you would want a BA/F comp cover. The 3582 can make more power, I think Ford went slightly smaller in the FG to improve response. If you wanted to go a bit smaller you would be better off swapping the whole turbo. If you wanted to make your turbo FG spec you would need the comp wheel changed and then have the CHRA balanced as well as the FG comp cover. A lot of mucking around. I'd just try to get my hands on a BA/F cover and leave it at that. Share this post Link to post Share on other sites
matt_lamb_160 252 Posted May 26, 2014 <p>Ok, that sounds better (some how I misunderstood and thought only the FG turbos had the smaller front). I don't really want to swap comp wheels. I need a BA/BF comp cover.<br /> </p> <p>Thanks for your help.</p> <p><br /> With the 0.7 A/R cover the compressor side is a bit too big for a 4ltr which sees rpm as low as 1,500 judging by the compressor map, which explains what Ford did. The smaller front will improve low end efficiency, reduce heat and avoid surge better.</p> <p><br /> When I was looking for a new turbo I wanted something with specs like the FG turbo you have described (I didn't know about them), but with a 0.82 A/R rear and external gate.</p> <p><br /> I looked at all different brands and all of the ones with suitable fronts had too small a turbine. I went for the Garret as its efficiency made up for the comp being too big.</p> <p> </p> <p>Should have got an FG turbo and changed the rear.</p> Share this post Link to post Share on other sites
matt_lamb_160 252 Posted May 26, 2014 WTF, why did that go all weird? Hope you can read what I have said. I cannot fix it (tried editing) Share this post Link to post Share on other sites
XPT 673 Posted May 26, 2014 A bigger exhaust housing will help with surge, Ford used a 1.06ar exhaust housing on the XR6T. My understanding of Compressor surge is where the compressor is flowing more air than the engine can swallow and occurs until the engine can consume this compressed air .A mismatched turbine wheel and compressor can cause this also (large comp wheel small turbine wheel). A larger turbine housing and or turbine wheel slows the spool rate and allows the engine to get into the rev range where it can consume the air. The GT3582r is a great match for the 4L, the 0.82 housing is maybe a size too small for maximum top end power (compared with 1.06ar) but hardly think it would be small enough to be causing surge. I would have thought the bigger comp cover would help with surge as it's larger internal volume would allow the compressed air to flow away more efficiently. I thought having the smaller comp cover was more to aid low down torque and spool time. Unless there's actually a space requirement for the smaller comp cover, I'd leave it alone. I think you got it pretty much spot on with your choice of turbo. The FG Turbo uses a smaller comp wheel and higher boost pressure to help achieve a broader torque curve and higher power output than the earlier models. Of course the trade off is that it sacrifices top end power potential. Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted May 26, 2014 even the FG turbo is more than capable of over 300rkww on a 4.0.... super responsive too, from memory they make full boost by 3K @ 1 bar. Share this post Link to post Share on other sites
matt_lamb_160 252 Posted May 26, 2014 There is a space requirement. But I may get away with making a new engie mount (turbo will be low mount). Or I could just use my Mike Vine top mount log mani. Share this post Link to post Share on other sites
XPT 673 Posted May 27, 2014 If it's not a maximum effort, record breaking build then (which by your choice of turbo it's not) the Mike Vine manifold will probably be fine. Remember BA/BF turbos can punch out 400rwkw with the factory cast manifold. Share this post Link to post Share on other sites
matt_lamb_160 252 Posted May 28, 2014 Yep, that manifold will not limit me at all. I just want a low mount. Share this post Link to post Share on other sites
XF0747 69 Posted June 22, 2014 if your getting a turbo of a fg make sure its of the xr6t the fg f6 etc had the same size turbo as ba/bf Share this post Link to post Share on other sites
matt_lamb_160 252 Posted June 22, 2014 I ended up getting the 0.7 A/R cover to fit (just). Thanks though. Share this post Link to post Share on other sites
