XFGHIA747 76 Posted May 13, 2014 Hey Men Just Wanting To Look At All Your Cleveland Gas Setups anything From Basic To Full LGI Setups so post up some pics of what you all have cheers Jake. Share this post Link to post Share on other sites
RAWDEAL 222 Posted May 13, 2014 I run a torker 2 on the 5.0 windsor , using a 650 baseplate, modded the TPS to make it work on the 351 i ran a Impco425 and an Xcellerator manifold Share this post Link to post Share on other sites
hendrixhc 10,920 Posted May 13, 2014 This is the setup on old Lucy Lu! I recon its pretty ugly and cant wait to piss it off. It has an Impco 425 carby on it and standard air filter ( its only saving grace)! Share this post Link to post Share on other sites
Stevemack 122 Posted May 13, 2014 I have just removed a gas research throttle body setup off mine, great system, just for the price of gas i could get better power off petrol, probably cost less too. 1 Trev Vaa reacted to this Share this post Link to post Share on other sites
XFGHIA747 76 Posted May 13, 2014 Trouble is guys my xf is 86 gotta run gas to pass rego bloke from transport told me I gotta remove tank and lines to but engineer dont think so, will find out shortly hopefully dont need to remove to put back in lol Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted May 13, 2014 i did a twin GRA setup on an XF last year, absolutely awesome gear, very easy to tune. ran a mild 351 (bout 320-350hp), and got the GRA adapter to holley 4150 pattern, that engine performs faultlessly, mainly because it has been tuned and setup properly, surprisingly has run on straight gas since the motor was brand new too with 0 issues. i'll see if i saved any pics of it. 2 XFGHIA747 and Stevemack reacted to this Share this post Link to post Share on other sites
Stumps 311 Posted May 13, 2014 Hmm Not sure about Tassie's rego requirements but in NSW an XF with a V8 is a reasonably easy thing to get passed as long as u meet the car original requirements, couple of blokes I know have just copied XE falcon emission specs and got by, but they were pre 86 XF's as well I would imagine a post 86 model would be a fair bit harder to get passed. Share this post Link to post Share on other sites
XFGHIA747 76 Posted May 14, 2014 Hmm Not sure about Tassie's rego requirements but in NSW an XF with a V8 is a reasonably easy thing to get passed as long as u meet the car original requirements, couple of blokes I know have just copied XE falcon emission specs and got by, but they were pre 86 XF's as well I would imagine a post 86 model would be a fair bit harder to get passed. Yeah mine is post 86 there is no issue with transport of the engine going in as I have all my application approved I can put 460 in if I like long as it is run purely and soley on lpg witch kind is gay I cant even leave my fuel tank in aparently but thats up to my engineer ill just hook up the gas and leave tank in place see weather he says anything.. Share this post Link to post Share on other sites
Stumps 311 Posted May 14, 2014 you could always get a cobrajet style manifold and run 2 impco 425's on that with a cobrajet style air cleaner that would look pretty sweet if you could hide the converter well enough. It should make some decent power if you cam and set up the ignition right. 1 gerg reacted to this Share this post Link to post Share on other sites
XFGHIA747 76 Posted May 14, 2014 Got any pics of a setup like that? Just the manifold could hide the converter behind a nice alloy or stainless shroud with some condue on all the pipeing would look pretty neat. Share this post Link to post Share on other sites
bear351c 10,270 Posted May 14, 2014 Yeah mine is post 86 there is no issue with transport of the engine going in as I have all my application approved I can put 460 in if I like long as it is run purely and soley on lpg witch kind is gay I cant even leave my fuel tank in aparently but thats up to my engineer ill just hook up the gas and leave tank in place see weather he says anything.. It's about the same in SA. Can run 427 etc in AC Cobra's but, on straight Gas. It has to do with emissions, Carbon Monoxide and shit. LPG makes bugger all compared to petrol. In SA, you can get a defect for having a tank in the boot, with the whole Gas set up ripped out !! Share this post Link to post Share on other sites
RAWDEAL 222 Posted May 14, 2014 This is the setup on old Lucy Lu! Is that a primer i spot there for the gas? Share this post Link to post Share on other sites
gerg 10,871 Posted May 14, 2014 LPG makes bugger all compared to petrol. In SA, you can get a defect for having a tank in the boot, with the whole Gas set up ripped out !! I had my gas Corty on my mate's engine analyser and he couldn't believe how clean he could get it to idle. Normally the cleanest you can get a non-cat petrol engine is around 4.5% CO and 250 ppm HC. Winding the mixture up or down causes one or the other to increase. On gas it was below 1% CO and below 100 ppm HC, as clean as or better than a cat-equipped car. He'd never put a gas car on the machine before and thought there was something wrong with it. Share this post Link to post Share on other sites
hendrixhc 10,920 Posted May 14, 2014 I believe so. i was having trouble starting the bastard when i first got it. I tracked down this solenoid connected to a dodgey relay which connects down to the starter solenoid. 2 of the wires were off the relay and when connected back up the thing started like a dream! Share this post Link to post Share on other sites
Stevemack 122 Posted May 14, 2014 Twin GRA setup is a sweet thing, runs faultlessly for years after a proper tune, not heaps of bloke can do it though, because the metering rod often needs to be machined to suit the engine. But again you really never have to put a spanner on it! Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted May 14, 2014 I had my gas Corty on my mate's engine analyser and he couldn't believe how clean he could get it to idle. Normally the cleanest you can get a non-cat petrol engine is around 4.5% CO and 250 ppm HC. Winding the mixture up or down causes one or the other to increase. On gas it was below 1% CO and below 100 ppm HC, as clean as or better than a cat-equipped car. He'd never put a gas car on the machine before and thought there was something wrong with it. i beg to differ, i've seen plenty of well tuned carby cars below 2.5% CO (inc my XC at one point) including some ones that make 450+hp all it requires is a proper tuner, many cars are tuned inefficiently finding someone who has that finest touch is hard but makes all the difference. the most surprising i have ever seen is a 393 turbo cleveland putting out near on 2% with a blowthrough setup, i couldn't beleive it when i read it, its an SA car too. Share this post Link to post Share on other sites
gerg 10,871 Posted May 14, 2014 the most surprising i have ever seen is a 393 turbo cleveland putting out near on 2% with a blowthrough setup, i couldn't beleive it when i read it, its an SA car too. Don't doubt it for a second mate and the key word I think is tuning. Factory setups are a repeatable, mass-produced state of tune (hence the rather loose standard) whereas our machines are more finely-honed instruments, having lavished much more time and money on getting them right. A bit of comp helps a lot in that respect but one thing I haven't mentioned is NOx, which makes it a three-way battle to get it running clean. Anyways I digress.... LPG is awesome! 1 Trev Vaa reacted to this Share this post Link to post Share on other sites
djjase 10 Posted November 23, 2015 This is my setup on 351 in XF ute - it's gas research 1 gerg reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted November 23, 2015 Nice GRA set-up. Is that a serpentine conversion as well.?? Share this post Link to post Share on other sites
djjase 10 Posted November 23, 2015 Yeah the March Performance setup - cost $2500 - it's the complete kit with air con, power steering etc 1 bear351c reacted to this Share this post Link to post Share on other sites
