78xcgxl 241 Posted April 25, 2014 Hi all,I'm fitting a AU engine into a XC falcon and when i was removing the engine out the AU i took no regard to any of the manifold vacuum switch setup or canister and canister purge under the LH guard. I have no idea how the setup is hooked up and does anyone have a diagram or pictures of the setup. I need to know where all the pipes from the canister go and the vacuum setup for BBM manifold vacuum. I have searched all over the Internet but will no luck, any help would be much appreciated.This is the carbon canister i'm talking about. Share this post Link to post Share on other sites
nos2 751 Posted April 25, 2014 Will pictures from an au help at all man? 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
unfamilia 1,938 Posted April 25, 2014 Au emmisions diagram would. Im sure a hunt around an au would point you in right direction. Share this post Link to post Share on other sites
78xcgxl 241 Posted April 25, 2014 Will pictures from an au help at all man? Yeah that would be awesome mate, if not to much trouble. Au emmisions diagram would. Im sure a hunt around an au would point you in right direction. I've look all over the internet and forums with no success, i'm probably going to go to pick-a-part and remove a complete setup off an AU and whack it in. Share this post Link to post Share on other sites
