Sign in to follow this
78xcgxl
Please Help: BBM vacuum and cainster vacuum setup.
Hi all,
I'm fitting a AU engine into a XC falcon and when i was removing the engine out the AU i took no regard to any of the manifold vacuum switch setup or canister and canister purge under the LH guard. I have no idea how the setup is hooked up and does anyone have a diagram or pictures of the setup. I need to know where all the pipes from the canister go and the vacuum setup for BBM manifold vacuum. I have searched all over the Internet but will no luck, any help would be much appreciated.
This is the carbon canister i'm talking about.
Will pictures from an au help at all man?
Yeah that would be awesome mate, if not to much trouble.
Au emmisions diagram would. Im sure a hunt around an au would point you in right direction.
I've look all over the internet and forums with no success, i'm probably  going to go to pick-a-part and remove a complete setup off an AU and whack it in.
