Damien Brazendale 11 Posted March 6, 2014 Just as the title says. Au starter into clevo. i read somewhere that they fit apart from needing a little grinding off the end. is this even tru, and if so who has done it and how??? Share this post Link to post Share on other sites
KRUPTOR 929 Posted March 6, 2014 Sorry mate its been done to death.Do a search bud. Share this post Link to post Share on other sites
Scott0568 64 Posted March 6, 2014 Just a silly question ,why an au starter , if you need a small body one ,their is plenty on market that just bolt straight in !! Scottie 1 Trev Vaa reacted to this Share this post Link to post Share on other sites
Jonathan Mark Davidson 169 Posted March 6, 2014 au cheap easy i'll grap a pic of what to grind and you have to buy a nut and bolt for one side Share this post Link to post Share on other sites
Jonathan Mark Davidson 169 Posted March 6, 2014 the blue is where the original part of the started was Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted March 6, 2014 just grab a powermaster unit. i've got a few. they are cheap now anyway. Share this post Link to post Share on other sites
Ants 6,370 Posted March 6, 2014 They won't fit pre xa, the throw out fowls.the new ones to suit clevo are cheap now, I'm cheap too though so I tried the au type first. 2 Stevemack and ILIED reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted March 6, 2014 I've fitted a cross-flow starter to mine, there's a write up here on how I did it: http://www.xfalcon.com/forums/index.php?/topic/38734-6-cyl-crossy-starter-to-clevo-any-issues/?fromsearch=1<br /><br />You'll either need to drill both bolt holes out to 3/8" and use a through-bolt and nut on the top one, or drill just the bottom one and tap out the top one to 3/8" UNC to take the standard Clevo arrangement. Share this post Link to post Share on other sites
ILIED 316 Posted March 7, 2014 I just bought for my F100Does the job Share this post Link to post Share on other sites
bear351c 10,270 Posted February 16, 2018 On 3/6/2014 at 9:33 PM, Jonathan Mark Davidson said: the blue is where the original part of the started was Just bought one for my Clevo, gonna get busy with the Dremel........ Half the size, half the weight, solenoid down around 8 o'clock, what's not to like..? Share this post Link to post Share on other sites
gerg 10,871 Posted February 16, 2018 Just bought one for my Clevo, gonna get busy with the Dremel........ Half the size, half the weight, solenoid down around 8 o'clock, what's not to like..? We had quite a few failures from BA ones, but they got worked hard. They mostly let go in the solenoid.Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted February 16, 2018 We had quite a few failures from BA ones, but they got worked hard. They mostly let go in the solenoid.Sent from my CPH1607 using TapatalkI’ve been to heaps of territories and falcons around 2006 models, they must have had a batch of duds, no click, nothing. Just dead in the water. All others seem fairly strong though except for lpg powered ba onwards that are cranked too long on start up. 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 16, 2018 I’ve been to heaps of territories and falcons around 2006 models, they must have had a batch of duds, no click, nothing. Just dead in the water. All others seem fairly strong though except for lpg powered ba onwards that are cranked too long on start up.Yeah that's probably about the era that we had, mostly one-tonners in our fleet: BA to BF. We stopped buying at FG. Same thing, turn the key, nobody home. I remember collecting the old starters for "Spares" lol, but all of them had the same problem: solenoid went open circuit. Shit job changing them too. That top bolt is a bitch. I got a long extension through from the front of the engine. Sent from my CPH1607 using Tapatalk 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted February 17, 2018 The AWD Territory’s are hell on earth to change a starter. The front diff sits right underneath the starter motor 1 gerg reacted to this Share this post Link to post Share on other sites
