unfamilia 1,938 Posted February 9, 2014 Im getting pissed off as ive had to seal my water pump since installing new motor 3 times. The top drivers side bolt leaks slightly. Every time. Its the only pump I've dealt with that has a plate separating the water pump casting from the block. I dont have a gasket kit so been trying with goo. Ive only just realised I havent gooed between the plate and the cast pump. Only on the plate and surface to the block. Is this usual to have to have 2 seals on these things. Having ac doesnt make it a quick job. Have to remove alt and all the brackets and loosen and move ac compressor. Grrrr Tips anyone Share this post Link to post Share on other sites
adrianphu123 73 Posted February 9, 2014 it should be block - sealant - paper gasket - sealant - plate - paper gasket - water pump. Did you put thread sealer on the bolts? The top drivers bolt also holds the alternator bracket. Could you have loosened the bolt while moving the bracket to put the alternator back on? Did you scrape all the old gasket off the block? did you clean the threads of the bolt and the bolt holes? If you can live without aircon, take it off and grab the alternator only bracket. Looks a lot cleaner, belt changes are a lot easier 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
unfamilia 1,938 Posted February 9, 2014 Scraped off all the old gasket from block. Didnt use thread sealer on thread. Do you mean plumbers tape? Theres no paper gasket between plate and pump housing. Looks like its all coming out again Share this post Link to post Share on other sites
ando76 4,354 Posted February 9, 2014 sounds to me like it is leaking through the threads - get some pipe sealant on those threads - plumbers tape will do the job but its a bit dodge. I use CAT pipe sealant - bloody great stuff, but any of the other name and non name brands will do. I have only ever put a light smear of silicon sealant on the paper gasket to block area. Never had a leak. If you are blocking off the heater hose outlet - then tap the thread and put a proper alloy bung in with some pipe sealant on it. Heaps better than a dodgy rubber bung that was never meant to see heat - like most of them. This is also a good stealth way to block heaters off for roady - well so some people have told me. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
unfamilia 1,938 Posted February 9, 2014 Might just renove bolt and put plumbers tape first. Not as dodgey as stuff ive done before. Mag wheel nuts clamped in the hose are great to block heater hoses and way better then plastic bungs. Share this post Link to post Share on other sites
adrianphu123 73 Posted February 10, 2014 just use whatever you used to seal the water pump to the block. give that a try first. If its not leaking between the pump and the block then leave it. they usually do have a gasket between plate and pump so you might have just not taken notice when you installed it. No point touching it if its not leaking. Replace bolts one by one, not all at the same time Share this post Link to post Share on other sites
unfamilia 1,938 Posted February 10, 2014 Was the pump from my old motor as the pump in the newer one was leaking from the pressure release hole in the pump. So I dindnt have gaskets only goo. Will try it later tonight its only from that one spot its got the slight weep leak. Share this post Link to post Share on other sites
bear351c 10,270 Posted February 10, 2014 Pretty sure you can buy both gaskets from Autopro/Repco. Silastic the threads and the shafts of the bolts. Share this post Link to post Share on other sites
unfamilia 1,938 Posted February 10, 2014 Oohhh bear.... stop talking about shafts. Share this post Link to post Share on other sites
bear351c 10,270 Posted February 10, 2014 Settle, Gretel. Share this post Link to post Share on other sites
Ando81 2,949 Posted February 10, 2014 One thing I've learnt over the years is that using secondhand parts might seem cheap at the time but the headaches that come with them definitely outweigh the savings. No offence man but if you can afford the new parts go with them every time. Especially where it's an engine part, fair enough on panels and stuff but more vital engine parts I reckon should be new. Just my opinion Share this post Link to post Share on other sites
unfamilia 1,938 Posted February 10, 2014 I agree ando the pump worked fine in old engine. Its just sealing it up from this weep. Rest of stuff going great. Hope to have new tank in the car next coupe nights. Share this post Link to post Share on other sites
gregaust 319 Posted February 14, 2014 Try sealing the bolt threads. It might work. Use a thread sealer. The gasket between the plate and pump is not really replaceable Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
unfamilia 1,938 Posted February 14, 2014 Well sealed leak at top bolt. Now sprung one on lower face.... it all has to come out AGAIN!!!!!!!!!! F@RK Share this post Link to post Share on other sites
Gaz 1,085 Posted February 14, 2014 I've got a new pump in Melbourne outer eastern suburbs you can have for 25. And there's an old mechanics trick to avoid dismantling the whole car to install them. Share this post Link to post Share on other sites
unfamilia 1,938 Posted February 14, 2014 Oh id love the old mechanics trick to getting them out in a car with ac. Is it ac water pump or smaller non ac one Share this post Link to post Share on other sites
Gaz 1,085 Posted February 14, 2014 afaik all XD 6 cyl water pumps are the same, but I was wrong about something once, so this could be the second time. Share this post Link to post Share on other sites
unfamilia 1,938 Posted February 14, 2014 Ok. Has she forgiven you for being wrong yet? 1 Ando81 reacted to this Share this post Link to post Share on other sites
unfamilia 1,938 Posted February 17, 2014 Ok so water pump was not leaking out the pressure relief hole but I can see the shaft through the hole. Are they usually plugged with wax or something? Is the cavity sealed from the water gallery where the impeller is Share this post Link to post Share on other sites
Gaz 1,085 Posted February 17, 2014 No, not plugged. Yes it's sealed You know that orange shit takes between 24 hrs to 7 months to cure don't you? Share this post Link to post Share on other sites
unfamilia 1,938 Posted February 17, 2014 Yep. Left it 36 hours last time..... grrr Let me know if you found seals with that pump Share this post Link to post Share on other sites
bear351c 10,270 Posted February 17, 2014 The weep hole is there to tell you that the machanical seal inside is FOOKED.! If water is coming out, your WP is cactus.... Share this post Link to post Share on other sites
Mr Polson 10,214 Posted February 17, 2014 Just go buy a new water pump. And get proper water resistant sealant, wherever you get the pump from should have a sealant for water pumps/thermostat housing. When you install the new pump make sure you've got a decent amount of water out of the block so it's not leaking over the edge and making the face of the block where the gasket goes wet. It should be totally dry for a good seal. Share this post Link to post Share on other sites
unfamilia 1,938 Posted February 17, 2014 Its not leaking out relief hole. Am getting another pump. Sealant I used was rtv red. Shop said use rtv blue so I got that. 1 Ando81 reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted February 18, 2014 Stick one end of a rag in the hole when you take the pump off, and leave the other end hanging down low. Should syphon the water out while you down a coldie. 1 unfamilia reacted to this Share this post Link to post Share on other sites
