90XFUTE 0 Posted September 27, 2013 theres a slight reacurring hiss coming from around under the carby or forward of it, its idleing ruff and has a violent shake to it, i think its an air leak. i cant seem to find is there a common hose that stuffs up or is there an easy way to find it? any advise would be much appreciated Share this post Link to post Share on other sites
Thom 6,650 Posted September 27, 2013 Spray some crc or wd40 or something.equivalent round the base of the carb with the engine running, a change in rpm means you have found the leak Share this post Link to post Share on other sites
deankxf 20,286 Posted September 27, 2013 the one that goes to the oil cap? or pcv valve is one the hose goes stiff and can split 1 Thom reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted September 27, 2013 There is a few different vacuum hoses from the manifold to the carb that can perish or fall off one end. If you leave the engine running and have a listen and feel around it won't take long to find the leak. The leak will be causing it to run like crap. Sometimes a bit of electrical tape wrapped around the hose can be a temporary fix until you can get the hose replaced. Good luck! Sent from my iPhone using Tapatalk - now Free 1 Thom reacted to this Share this post Link to post Share on other sites
