n00bus m@x1mus 465 Posted August 18, 2013 So yes i need to know if its the cast iron singlerail bell that you use to fit a toploader onto a 250 xflow. A mates trying to track one down. Share this post Link to post Share on other sites
Ants 6,370 Posted August 18, 2013 Yep, off the top of my head I believe it requires new holes drilled, but other than that is exactly the same. 1 n00bus m@x1mus reacted to this Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted August 18, 2013 Cheers, i thought that was the case. And the holes would be just holes right... dont need a thread tapped in them cos it bolts in thru to the box? Share this post Link to post Share on other sites
revhead 1,392 Posted August 18, 2013 if my memory is working ,no grog,lol i thnk the top left bolt hole is correct ,you need to drill then tap the other 3x holes Share this post Link to post Share on other sites
scottly 475 Posted August 18, 2013 revhead is right I had to do this with mine I cant remember the drill bit size or the tap size sorry Share this post Link to post Share on other sites
Gav 616 Posted August 18, 2013 Buy this : http://www.ebay.com.au/itm/Ford-6-cyl-single-rail-top-Loader-Bell-housing-/321185500719?pt=AU_Car_Parts_Accessories&hash=item4ac825ce2f It's a top loader one...not single rail as the ad. suggests...needs a hydraulic clutch though....pre-crossflow fits cross flow. Either way...there's gonna some kind of fiddling around. Share this post Link to post Share on other sites
