Tom Manning 0 Posted August 14, 2013 Has anyone ever tried shortening a diff without a jig? Anyone got any good methods of keeping the flanges true? Share this post Link to post Share on other sites
hendrixhc 10,920 Posted August 14, 2013 Check out slydogs tubbing a ute thread. http://www.ozfalcon.com.au/index.php?/topic/1526-how-to-tub-a-ute-slydog-style/ Mate that avatars a shocker! 2 steve mcqueen and slydog reacted to this Share this post Link to post Share on other sites
KRUPTOR 929 Posted August 14, 2013 Honestly get a reliable engineering shop to do the work if you dont know what you are doing. Share this post Link to post Share on other sites
Thom 6,650 Posted August 14, 2013 I've done it with my old man, slow process and reasonably difficult to achieve but it is possible,unless you've done fab work before I'd use a jig Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted August 14, 2013 Mate that avatars a shocker! Hendrix, you crack me up im still pmsl Share this post Link to post Share on other sites
hendrixhc 10,920 Posted August 14, 2013 Hendrix, you crack me up im still pmsl Wont say what i thought when i saw it! 1 dizzy616 reacted to this Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted August 14, 2013 Wont say what i thought when i saw it! No prizes for guessing is there? Share this post Link to post Share on other sites
blackxt 699 Posted August 28, 2013 What I do is machine locators that sit in the axle tube and inner bearing housing run a long peice of chrome bar through the housing . Cut the axle tubes off half way down the tube . Part off the tube to shortended length and weld it back together . As long as you make sure the bar still slides its pretty well inline. Mind you the chrome bar I use it worth 1000 or more dollars and I have a decent lathe as well. Share this post Link to post Share on other sites
PRO250 1,506 Posted August 29, 2013 i made a jig to do this. 4 collers 2 on the centre and 2 for the outer bearings. you drop saw the ends cut out what you want to shorten out of it and sit the collers in and then put a steel tube up the guts to hold it all straight and weld the tube and collers cost about $250 in blank steel and 3 hours work to make it work and fit most charge 3 times that to cut down a case before even doing axles Share this post Link to post Share on other sites
winton 399 Posted August 29, 2013 I shortened my diff without cutting the housing. pushed the axle deeper into it with some machining. (25mm each end) At first I thought about cutting the housing and using a sleeve to keep it straight, idea was to cut it about halfway down the axle tube, cut off desired amount , then put the sleeve over the axle tube, the outside diameter of the tube would have to be the same as inside diameter of the sleeve, knock them together and weld the sleeve to the axle tube. only a idea as I didn't do it and if the "sleeve " can't be bought straight from a steel supplier the cost of making them would make it not worth the effort . Share this post Link to post Share on other sites
Thom 6,650 Posted August 29, 2013 T model axle tubes fit perfectly as a sleeve for narrowed btr's, I prefer to have the sleeve in the same place as the spring pads so the joint is under far less load than if it was in the middle of the axle tube Share this post Link to post Share on other sites
slydog 7,873 Posted August 29, 2013 The further in-board you cut the more chance of a bent housing.1mm in the middle = prob like 3-4mm on the end. Share this post Link to post Share on other sites
winton 399 Posted August 29, 2013 good point but i could of put it onto some v blocks and pressed it straight after a tack weld. Share this post Link to post Share on other sites
KRUPTOR 929 Posted August 29, 2013 Locally to shorten a diff and axles $600,$150 each axle and each side of the diff housing. Share this post Link to post Share on other sites
winton 399 Posted September 1, 2013 I shortened my diff without cutting the housing. pushed the axle deeper into it with some machining. (25mm each end)I worked out I could put up pictures so I thought some off you would be interested to see what my axles look like with the different offset. this is a picture of original offset, sorry for the poor quality. and after. my original goal wasn't to shorten the diff but to replace the 25 spline axles with 28's. its a Cortina diff and I used r31 skyline axles. I could of sunk them another 10mm but would of had to respline one axle. in total they are 30mm shorter but once the disk is fitted you lose 5mm. Share this post Link to post Share on other sites
gerg 10,871 Posted September 1, 2013 So what are you doing about brakes now? Share this post Link to post Share on other sites
winton 399 Posted September 1, 2013 r31 skyline disks. Share this post Link to post Share on other sites
slydog 7,873 Posted September 2, 2013 Good work bruz... 1 winton reacted to this Share this post Link to post Share on other sites
