Mad RS
Single Rail Transducer
Hi,
  I have my car at club members house trying to get a few things sorted.  It seem like the transducer on my single rail is dead and from what I have found so far the replacement part is rarer the rocking horse shit.  I forgot to write down the part number but it is a red sheathed transducer.  I'm lead to believing that it is a Bosch F005S00070 10 pulse transducer.  Has anyone found a new replacement item that supersedes the F005S00070??  I had a speedo corrector wired in as the car has a EB diff.  I bought the car that way.
This is the item fitted.
Picture 1 of 1
Any help would be much appreciated.
Posted (edited)
The black 8 pulse one (XD XE) is the rare one
The red one is same even on AUs  (XF XG XH EA EB ED EF EL AU will all be same)
just need to change the gear on the end to suit the EB ratio, the corrector shouldn't be needed.
(unless it was in an XD XE, because the red 10 pulse one will read 20% higher with the same gear on it)
should be easy to find locally in wreckers,
but what often happens to them is one or more wires snaps off at the transducer end, could try soldering it on again if there's enough left on it.
here's ONE of 3 on ebay, $150.. seems dear, but ebay is convenient and maybe cheaper if you can find one from someone wrecking one of the above cars
https://www.ebay.com.au/itm/298141705342?_skw=speedo+transducer+XF&itmmeta=01KW1MTJT1SWPM4PHT849G9WFN&hash=item456aa1647e:g:UXwAAeSwkQVpvHqb&itmprp=enc%3AAQALAAAA0GfYFPkwiKCW4ZNSs2u11xCvVWbQijWydBZSB2KR5PfHa3bSEY4Bho3eG9%2FFPKLJDwOZUqAQIlAb2qHdUKtDWH%2FzMkXR73YKkGS4ig94FRBCqWR2yg5OdIDiVeJzFIkKOtG%2BsdKBrKY2zF7z%2BhDgINECUJqJ6ywHooklZXvu2hZf7d1P6NfC6VO54xj130AnMxAZGe2ybcKDT1e%2BiZ7YP5tGpTpjisVQ44M%2FWWRq7BAxRkAVs23GlQmVd8BMtpkUlc7hU4n9MGXsyteo%2BEbT99I%3D|tkp%3ABk9SR6Ct6rTgZw
Edited by deankxf
add ebay link for one
$150 for a used transducer seems excessive. Are there no new ones available??
you'd have to look around and see what you can find.
try the facebook groups etc for bargains (a mate bought a full BTR transmission from the wreckers with sender unit in it for $165 or something like that. )
