jsecond
XD/XE V8 Cluster Wiring Loom Plug
Hi, I am needing a XD/XE V8 S pak instrument cluster wiring loom, which plugs into the cluster, white circle plugs i think...if anyone could help thanks, or supply wiring diagram to know what each pin on the back of the cluster is for...cheers
the cluster loom is part of the main dash loom, is it for the car or test related purposes. The pin out should be in the manual the only issue is they arent that clear in the manual an copying them blurs even more. will check the manual and get back to you
DaLE
6cyl XD XE will be same V8 cluster is same other than the tacho calibration (adjustable also, can be changed to either with adjusting a trim pot and calibrated correctly)
even the GL without tacho will be mostly the same (i had one where the tacho wire wasn't in the XE we had, i just added it to the plug)
you can decode nearly all of the wires if need be by following the tracks on the circuit board (will need to undo the 6 screws on the back to release it from the housing.
what car is it going into?
Wiring diagram hard to read in manual may not pick up photo. If you need me to confirm wire colour let me know what you need to know70ce9e627c700538feb6cd197901149a.jpg
