Mick.G 48 Posted April 16 I only have two key's for the Ute , Glove Box and ignition/Door's . Is there suppose to be a third key for the Spare Tyre lock ? . Also if i drill the lock out will i need to use some MacGyver intuition to keep it closed till i find a new lock. Share this post Link to post Share on other sites
deankxf 21,673 Posted April 17 1 hour ago, Mick.G said: I only have two key's for the Ute , Glove Box and ignition/Door's . Is there suppose to be a third key for the Spare Tyre lock ? . Also if i drill the lock out will i need to use some MacGyver intuition to keep it closed till i find a new lock. i never trusted those latches on them, they often either stuck or didn't latch in my experience (perhaps because they'd backed into a trailer hitch etc too many times from previous owners they should match one of the keys (i think it's the door/ign key) *the one that fits in the hole... glovebox usually matched the sedan boot key. last ute i had, i pulled the tumblers out of the lock so a screwdriver would open it or any key that fit due to it being full of dust/dirt etc. if you suspect you have original door/ign locks, i'd firstly spray it with WD40 etc in the lock hole, in the gaps to the lock and try wiggling the key as you try turn it while putting upward pressure on the door. if you can figure out where this is in relation to the pin it latches to, you can drill a hole or poke and prod to release it. they can be really hard to open even when everything worked.. and hard to close (i screwed mine shut in the past due to them coming open on dirt roads) Share this post Link to post Share on other sites
Mick.G 48 Posted April 17 Thx for quick reply. Ignition/door key fit's the wheel lock...will give it a spray with WD 40 and give it a go . Was told i would need a crow bar to open it as i remember at Vehicle hand over. At least now i know i have the right key in lock while attempting to unlock it. Share this post Link to post Share on other sites
deankxf 21,673 Posted April 17 5 minutes ago, Mick.G said: Thx for quick reply. Ignition/door key fit's the wheel lock...will give it a spray with WD 40 and give it a go . Was told i would need a crow bar to open it as i remember at Vehicle hand over. At least now i know i have the right key in lock while attempting to unlock it. yeah they are pretty bad and very hard to line up to work properly. i've had several that had home made latches and gate locks etc and one had the pin filed down so it would close easier (this is the one that fell open easily) i used the number plate screws to screw into the panel behind . (did this by accident once also) good luck, if you can turn the key, it should come open with some prying Share this post Link to post Share on other sites
Mick.G 48 Posted April 17 39 minutes ago, deankxf said: yeah they are pretty bad and very hard to line up to work properly. i've had several that had home made latches and gate locks etc and one had the pin filed down so it would close easier (this is the one that fell open easily) i used the number plate screws to screw into the panel behind . (did this by accident once also) good luck, if you can turn the key, it should come open with some prying Just had enough DW 40 left in my Nozzle can to fill it up, After a few jiggle's and cuss word's it turn. it feels rough to turn so will go buy some more WD 40 before i open it too give it a service. thank's deankxf 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 21,673 Posted April 17 2 hours ago, Mick.G said: it feels rough to turn so will go buy some more WD 40 before i open it too give it a service. thank's grease the pin, it latches on, grease that spring latch part, oil the door hinges and oil/grease any of the mech parts.. if you probably drowned that key lock in some WD40 or similar it might flush the dust out of it.. ideally locks are supposed to have a graphite powder in them, but they can still get that oxidized build up that WD40 etc seems to prevent.. (for a rarely used lock, i'd go with the WD40..) you can pull the tumblers out of that lock easy which will also make it easier to turn. ..any key/screw driver will open it.. but it's not likely going to have people trying to get in there.... same process for the door locks if you wanted.. My Dad had one lock on his car without tumblers for decades and a spare ign key under the seat for when he went fishing.. just incase he lost his keys overboard etc. (these days they smash windows etc rather than play with locks anyway) 1 Mick.G reacted to this Share this post Link to post Share on other sites
