Harrison Kotrolos 33 Posted July 28, 2025 Hi all, Throwing it out there before I make the trip to engine builders. Is this crankshaft serviceable? Looks like it had a previous life of burnouts. The keyway was half squashed and the timing gear had play to wear the crank down. Am on the hunt to replace my bent crankshaft https://drive.google.com/file/d/1GI7cMHoTmeZD0tKasdzqKzA4PvI2caMq/view?usp=drivesdk Share this post Link to post Share on other sites
Harrison Kotrolos 33 Posted July 28, 2025 https://drive.google.com/file/d/1GI7cMHoTmeZD0tKasdzqKzA4PvI2caMq/view?usp=drivesdk Share this post Link to post Share on other sites
deankxf 21,673 Posted July 28, 2025 6 hours ago, Harrison Kotrolos said: Hi all, Throwing it out there before I make the trip to engine builders. Is this crankshaft serviceable? Looks like it had a previous life of burnouts. The keyway was half squashed and the timing gear had play to wear the crank down. Am on the hunt to replace my bent crankshaft https://drive.google.com/file/d/1GI7cMHoTmeZD0tKasdzqKzA4PvI2caMq/view?usp=drivesdk is it some rare crank? it's probably going to cost more than finding another, but there's ways things like that can usually be fixed to My understanding but the time/$$ would add up faster than the cost of another crank. Share this post Link to post Share on other sites
Harrison Kotrolos 33 Posted July 28, 2025 7 hours ago, deankxf said: is it some rare crank? it's probably going to cost more than finding another, but there's ways things like that can usually be fixed to My understanding but the time/$$ would add up faster than the cost of another crank. Nothing rare. Am trying to source another crank for my engine as the snub on it got bent. The block is an earlier one with the two-piece rear seal and flange on the crank, which I'm finding hard to replace, I have 3 newer cranks with the small and large rear main seal. Can I use later cranks in the earlier block? (I.e the single rear seal in a two piece seal block?) Share this post Link to post Share on other sites
deankxf 21,673 Posted July 29, 2025 6 hours ago, Harrison Kotrolos said: Can I use later cranks in the earlier block? (I.e the single rear seal in a two piece seal block?) i believe the later ones (same size journals as EF 4.0 etc ) are smaller, so not usable. assuming you mean a 250 crossflow, i can't remember ever person's project off the top of My head. Share this post Link to post Share on other sites
Harrison Kotrolos 33 Posted July 29, 2025 8 minutes ago, deankxf said: i believe the later ones (same size journals as EF 4.0 etc ) are smaller, so not usable. assuming you mean a 250 crossflow, i can't remember ever person's project off the top of My head. My bad, it is indeed a 250 crossflow. Got a few more engines I'm hunting down, but may need to take the approach on redoing a whole new block to suit the cranks I have. Unless someone on the forums has a earlier, flange crankshaft for a 250 crossflow lying around Share this post Link to post Share on other sites
deankxf 21,673 Posted July 29, 2025 58 minutes ago, Harrison Kotrolos said: My bad, it is indeed a 250 crossflow. Got a few more engines I'm hunting down, but may need to take the approach on redoing a whole new block to suit the cranks I have. Unless someone on the forums has a earlier, flange crankshaft for a 250 crossflow lying around make a wanted post, but generally either finding wreckers engines or facebook is usually the easiest way. the forums are pretty slow for ads generally. especially for something as heavy as a crank to pack and send safely. some engine reconditioners might have spare cranks sitting on shelves for 20yrs if they'd been around for long enough. Share this post Link to post Share on other sites
Rod Racer 546 Posted July 29, 2025 I have a complete running crossflow from a Bronco, if you are interested. Share this post Link to post Share on other sites
XF EDDIE 249 Posted July 29, 2025 I got one in qld I'm not using Share this post Link to post Share on other sites
