Mad RS 6 Posted April 3 I'm sure this has been brought up before but I can't find anything. I'm looking at a XE 250xflow manual and Ii'm wanting to do say 4-6 track days per year. Is there much difference moving up to the factory 351 brake setup?? I'm thinking surely the V8 stuff is more robust especially with slotted rotors and track pads. Share this post Link to post Share on other sites
deankxf 20,979 Posted April 3 1 hour ago, Mad RS said: I'm sure this has been brought up before but I can't find anything. I'm looking at a XE 250xflow manual and Ii'm wanting to do say 4-6 track days per year. Is there much difference moving up to the factory 351 brake setup?? I'm thinking surely the V8 stuff is more robust especially with slotted rotors and track pads. only difference with the V8 was rear discs, Vented on XE XE (even though EB V8s had solid discs) some say the V8s had PBR front calipers (iron ones like XC) but I've seen the Girlock (basically XF ones) on V8 cars also, and believe they are basically same performance wise. XE Ghia had rear discs 250crossflow standard (same with fairlane/LTD) they were basically V8 brakes other than the potential different front calipers(older Vs Newer) Hoppers stoppers do a "big brake" kit, which uses bigger rotors and AU series 2/3 or BA calipers from memory (could be commodore for all i know) these may need bigger wheels than 15" you'd then at minimum need a proportioning valve as the fronts will over power the rears i would imagine. very expensive, how fast are you going to be going? Share this post Link to post Share on other sites
Mad RS 6 Posted April 4 11 hours ago, deankxf said: only difference with the V8 was rear discs, Vented on XE XE (even though EB V8s had solid discs) some say the V8s had PBR front calipers (iron ones like XC) but I've seen the Girlock (basically XF ones) on V8 cars also, and believe they are basically same performance wise. XE Ghia had rear discs 250crossflow standard (same with fairlane/LTD) they were basically V8 brakes other than the potential different front calipers(older Vs Newer) Hoppers stoppers do a "big brake" kit, which uses bigger rotors and AU series 2/3 or BA calipers from memory (could be commodore for all i know) these may need bigger wheels than 15" you'd then at minimum need a proportioning valve as the fronts will over power the rears i would imagine. very expensive, how fast are you going to be going? hey Dean, Thanks for the great info. It's going to be mainly a cruise car but I would like to do the odd track day at Queensland Raceway and Lakeside so I would like to upgrade at least the pad and disc setup if not go a little larger. 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,979 Posted April 4 On 4/4/2025 at 11:37 AM, Mad RS said: hey Dean, Thanks for the great info. It's going to be mainly a cruise car but I would like to do the odd track day at Queensland Raceway and Lakeside so I would like to upgrade at least the pad and disc setup if not go a little larger. i guess the next question is how fast it's going to be going before it needs to stop and how often? I've never raced one, so no idea how they go or if better pads/slotted rotors are much better as with braided lines and race brake fluid.. @Rod Racer is setting up a race car AU currently but was considering an XE/F but can't remember what brakes he had planned, perhaps he would have some useful info for track days and brakes. Share this post Link to post Share on other sites
gregaust 334 Posted April 4 Braided lines I've found make a great difference . Perhaps good slotted rotors and good pads like ultimates or similar may get you where you want . In saying that I've used the RRS struts with the 300mm slotted rotors and pads work brilliant for me for street and the odd track day . Something like the 300 rotors and twin piston calipers are nice 2 bear351c and deankxf reacted to this Share this post Link to post Share on other sites
bear351c 10,425 Posted April 5 Agreed. So surprised at how much the old rubber lines swell up when under pressure, all that wasted energy that should be pushing on the pads. Share this post Link to post Share on other sites
Rod Racer 348 Posted April 5 On 4/4/2025 at 12:01 PM, deankxf said: i guess the next question is how fast it's going to be going before it needs to stop and how often? I've never raced one, so no idea how they go or if better pads/slotted rotors are much better as with braided lines and race brake fluid.. @Rod Racer is setting up a race car AU currently but was considering an XE/F but can't remember what brakes he had planned, perhaps he would have some useful info for track days and brakes. I was planning on using the Hoppers Stoppers 13" brake kit with the twin piston PBR calipers and appropriate pads, covered by AU S1 XR wheels and spacers. For a 'budget' brake set up, use good quality slotted rotors and the old Girlock calipers from XA and early XB falcons (with the wire retainer on the outside pad.) These calipers have a good sized pad to spread the heat and friction area really well. Metal king plus pads will give you good stopping power on the street with minimal fade, however, for track use, find something a little more aggressive. On various cars I found that in racing conditions, the places where brake performance matters is Sandown at the end of the front straight and Calder Park for the same reason, and from others experience, the Chase at Bathurst. 1 1 Mad RS and deankxf reacted to this Share this post Link to post Share on other sites
